TwinTurbo.NET: Nissan 300ZX forum - Thanks. Move to Tech VTF
induetime
on January 07, 2008 at 5:35 PM
Accelerator Cable Adjustment Reduced Driveline Kickback
posted by Gordo 93TT Daytona
on January 07, 2008 at 05:24 PM
I will have to try that. I have been trying to figure out what you described
for a long time but to no avail. VTF.
Gordo 93TT Daytona
17:24:33 01/07/08
Thanks. Move to Tech VTF -
induetime
17:35:13 01/07/08
A very lucid how to. Bookmarked. Thanks. (n/m)
240Z FeO2
17:44:17 01/07/08
My car had the same problem. I did the same (reduced
olyar15
17:49:15 01/07/08
Re: Accelerator Cable Adjustment Reduced Driveline Kickback
naZeer (Dallas)
17:57:20 01/07/08
You are on a mission.
Boosted1
18:51:50 01/07/08
Yes I did. New 98+trans, rebuilt diff, 2 ea. drive axles,
Gordo 93TT Daytona
19:40:42 01/07/08
Nice (n/m)
collegeboy
18:53:32 01/07/08
No
NytWolf
21:54:43 01/07/08
There should be some, but not much. I usually adjust
Guapo
22:01:51 01/07/08
There should be about double that amount of slack (n/m)
NytWolf
22:04:21 01/07/08
why? (n/m)
Guapo
22:09:20 01/07/08
Because
NytWolf
22:10:15 01/07/08
Shrug. Been doing it that way for years now, and
Guapo
22:18:34 01/07/08
Same idea as why you adjust your clutch pedal
NytWolf
22:25:18 01/07/08
right. And half a turn is plenty on the throttle cable
Guapo
22:26:24 01/07/08
Not enough slack (n/m)
NytWolf
22:40:13 01/07/08
you're wrong (n/m)
Guapo
22:45:53 01/07/08
You are
NytWolf
23:25:33 01/07/08
lol
Guapo
23:31:10 01/07/08
I agree that you do not want the cable to be so tight as to
Gordo 93TT Daytona
22:16:55 01/07/08
Your procedure still leaves the cable tighter than should be (n/m)
NytWolf
22:26:05 01/07/08
FSM spec says tighten until rod pulley moves, then back off
Gordo 93TT Daytona
08:14:39 01/08/08
Where in FSM? (n/m)
NytWolf
12:07:58 01/08/08
Section FE-2 (n/m)
Gordo 93TT Daytona
13:33:27 01/08/08
Nytwolf why are you so adamant about this?
fanta-z
18:07:25 01/08/08
If it seems like I am adamant about this
NytWolf
10:55:14 01/09/08
